I thought Tom had a video or post about installing Untangle in front of USG, but I’ve searched and can’t find anything.
Here’s my current setup:
Cable modem -> USG Pro 4 -> UniFi Switches / APs / Etc
Here’s the setup I’d like to create:
Cable modem -> Untangle -> USG Pro 4 -> UniFi Switches / APs / Etc
I need the performance of Untangle for things such as IDS/IPS, but want to keep the USG so my UniFi environment stays graphically pretty I also have a regular USG (non-Pro) available if that would make this task easier?
Thanks for the great videos and sharing of knowledge!
To be honest, Untangle is likely to have vastly better metrics than whatever Unifi will give you. The USG’s DPI and other “stats” features are not the most accurate or actionable. If all you’re going for is to have this
look like this
You should be able to do that by disabling NAT and opening up the firewall rules to any any.
I plan to use the fully licensed Untangle appliance for all UTM functionality. The USG/Pro would only be there for the stats it provides. Perhaps this stems from the a deep-seeded desire to have all of the UniFi dashboard bubbles lit up back in the day! LOL
