Unifi Teleport to a single vlan/subnet
I have been using unifi equipment little less then a year at this point and I love it. I just completely switched off of PfSense.
I currently have: UDM Pro + USW 10G Arg Sw+ 2 U7 Pro AP’s + 1 Pro XG 8 PoE 8-Port 10GBE Poe++ Switch
Right now I use tailscale as my vpn which i have running off of my UDM Pro and its been working great. I use it basically when I need to VPN to 1 of my vlan/subnets when im away from my lab.
I have been starting to try the teleport feature which so far I like and seems very simple but it seems it gives me access to all my networks/vlans, which I do not necessarily need.
Is there a way using the teleport where I can set it to do something simiar to what I do with tailscale where it points and gives me access to the only subnet/vlan I need vpn access too, maybey some firewall rules I can set or is this just something thats is to the teleport where I will just have access to all vlans/networks.
Yes, the rules are very open by default with the UniFi VPN. I have a video on how to secure them.
thanks tom, will give this a watch. appreciate ya.
