Bear with me as there is a backstory and a detailed outline of my network setup.
A couple of weeks ago, my UDMPro took a shit. IT decided to go into recovery mode everytime I unplugged and plugged it back in. Since I have mission critical services going on, I could not afford to be offline for an extended period of time. (I run my own business and youtube channel out of my home). I decided to go to Microcenter (local computer store) and purchased a cloud key gen2+ along with the rackmount accessory. The setup and initial configuration was easy as pie and I did not have any issues, that was until I decided to setup Unifi Talk on it and thats where the issue starts:
Unifi talk keeps going offline for no obvious reason. I have tried google search and have not come up with any good info there. So with that being said, here is the setup for my network:
ISP is Frontier (Modem)
The ISP is connected to my Untangle Firewall
The Untangle Firewall is connected to the USG Pro. (There are no specific rules on the firewall for Unifi Talk).
The USG Pro is connected to a 24 port switch
The 24 Port Switch is connected to an 8 port POE Switch
The POE Switch is then connected to the cloudkey gen2+
I have run just about every test that I can think of and I am not finding the obvious error. I am guessing that the firewall or the ISP may have something to do it but I am not sure. I would appreciate any suggestions/thoughts that would be helpful. Maybe its so obvious that I can’t see it.
