I have a switch that I restarted after making a port profile change and now it won’t adopt and is stuck IP address of 192.168.1.20(default?) What is the best or simplest resolution for this issue?
Have you tried to reset it?
Over ssh with command set-default
What @beli3ver said. Use the reset button on the switch or if you can SSH to the switch do the set-default. Although, I’ve found that command not to be as useful in certain situations. The reset button on the switch was the one that worked. That said, I would recommend trying the set-default via SSH first.
so once I got on site I could reset it with the reset button
now time to try create vlans between sonicwall/unifi ![]()
