hi all,
First Thank you Tom for all of your great videos they are really helpful.
I have recently setup a pfSense installation on a Protecteli box, a Unifi 8 port POE switch, and Unifi AC Pro access point to replace my ISP router. The issue I am having is that my unifi controller on my PC is stuck trying to adopt the switch and AP. If I take the pfsense box out of the loop and just use my original ISP router the controller adopts them no problem. This is how I had to original set them up. It seems something in the pfSense configuration is blocking it but I have no idea what.
Here is the basic setup
ISP
pfSense - 192.168.10.1
unmanaged switch
unifi controller v 6.0.43.0 (windows 10 pc) 192.168.10.10
unifi 8 port switch 192.168.10.11
unifi access point 192.168.10.12
As you can see everything is on the same subnet and the firewall rules in pfSense are very basic. I recently added the two rules in the screen shot dealing with port 8080 on the controller in the hope that might help.
I am completely lost as to what’s going on. I have tried many of the usual suggestions when a device won’t adopt in Unifi such as SSHing into it to set the inform setting and upgrading the firmware.
Any thoughts as to what might be causing this?
Many thanks for any help.
