So I built a new computer, reinstalled Linux and Windows. Installed the Unifi software. Logged in, and apparently I should have backed this up as well. It sees my APs, but I can’t do anything with them as it wants me to reset them and adopt them again.
I only use the software for the APs which are functioning with all the original settings? Is there a way to get the software to see this, or am I stuck resetting everything?
Unfortunately no. Those drives went in my son’s “build”, and also got wiped to be new OS drives. It is only running in Windows. I honestly didn’t realize it was all running locally. Before the “wipe” I had installed it to Linux, but hadn’t logged in. I guess that would have made me realize it was running locally.
Well that’s what I was afraid of. Not to big of a deal. I assume if I use the backup option, and have a backup going forward, I can prevent this in the future? (Just restore rather than reset everything?)
Side note, this was was actually the only part of my network I didn’t have a backup for, as since it makes you login with a UI account, I mistakenly thought it was cloud based, DOH! I actually am kind of glad it’s all local, and you have to manually turn on the option to send off information though.
