Hi,
I have to route the wan from my ISP (Vodafone) to two opnsese firewall via vlan. I have static IP’s from my ISP, HA (Carp) is not configured on the WAN ports of the firewalls at the moment. HA is succesfully implemented on serveral other ports and vlans of the two firewalls and runs without an issue.
As soon I plug in the two firewalls together in the unifi switch I got a broadcast storm which takes down my complete network.
If only one of the firewall is plugged in the vlan-wan-port it works as expected. One firewall and a other device (laptop), it works as expected. If I activate port isolation for the wan-vlan (, so no CARP/HA possible,) on the unifi switch for the wan-vlan ports, it works as expected. Other Vlan networks (same firewalls, same switch) works without an issue (CARP/HA is activatedin the other vlan’s).
Any hints or settings I should try to get both firewall up and running in HA together?
