Hello,
maybe a stupid question, but can i use ONE CC to configure two networks in two locations or does the unify OS need to be running for the respective network at all times?
If it needs to run at all times, can i “start up” the network with a CC and then move this configuration to a virtualized one on a NAS in that network?
Than you
You can use UniFi controller to setup the devices and then turn it off but you will lose the device stats, captive portal, and any device notifications.
Hello Tom,
Thank you for the information. When i set it up with the CC, can i the move/push the config to a VM on a NAS within the network to still provide the mentioned services?
Regards
