hi
I am planing to rebuild my home network. I am not sure about router yet, still thinking between edge router 4 or some pfSense / openSense hw.
What I need or plan is to have separate IoT network (both cable and wifi) and separate quest wifi network.
I have done some research and these are my options:
#1
switch : edge switch 8 150W
wifi AP : airCube AC
cost 256€
#2
switch : unify switch 8 150W
wifi AP : unify AC Pro or Lite
cost 330€ or 269€
question #1
edge switch 10xp is bit cheaper and has “simple” POE but could be OK
do you think that network performance is similar to ES-8-150?
question #2
airCube is cheaper than unify AC pro or Lite.
what do you think about performance? is it comparable?
question #3
unify switch 8 - 60W is cheaper, what about network performance?
What I learn is that edge products are more (or better) configurable over UMTS or over device web interface. So I prefer option 1.
what do you think?
thank you for comments and answers.
