I’ve got a network, simplified to what’s shown in the attached drawing. The existing network traffic is on VLAN 20 with management traffic on VLAN 1. I’m using Unifi gen 2 switches – a 48 port and a 16 port switch. (There’s a firewall, too, but that should be irrelevant for my question here)
We’ve got a multi-cast TV setup (internal video feeds from a video switcher to TV’s on campus), and we’ve run into an issue after converting from some older cisco to our unifi switches.
Our network design has us separating this traffic to its own VLAN (vlan 10). However, the unifi switches will not send the multi-cast traffic to another switch. Non-multicast traffic traverses the switches perfectly on the vlan, but the multi-cast does not. My first thought was to disable IGMP snooping, as this should force all multicast to go to all ports on the vlan, but this did not resolve the situation.
Interestingly enough, if I change the vlan to 1, which is the untaggd vlan for the unifi switches, the multi-cast traffic passes perfectly. However, I then run into another issue.
The CPU on the 48 port switch pegs at 100% while the mutlicast traffic is going to the switch. It’s about 60% when the traffic is disabled. The switches are connected with 10Gb SFP+ modules, and I’m running a total bandwidth of about 25M nominal without the multicast, and about 800M with. So traffic volume shouldn’t be an issue.
I’m at a loss as to what I could be doing wrong. The CPU spike is causing other issues, like dropped DHCP request and the cloud key to drop out. I’ve “fixed” this temporarily by limiting multicast to the cloudkey port to 100 packets/sec.
I did not have this issue with the cisco switches. Are there other configuration settings I should check? I’m out of ideas.
Thanks in advance!
