I just set up a UDM Pro Max and three UCG Ultra on satellite sites and use Magic SD-WAN to connect everything. This is a little bit of an spontaneous decision. I had pfsense on the main site and after seeing Toms latest video about this I decided to try this setup.
So far I have everything working… ish.
On the main site when viewing traffic from the satellite sites the only ip I see is the gw ip of the bridge network, I can not see the device local ip.
This has resulted in NPS (radius) not working when laptops are authenticating over the sd-wan and only way to fix this was to add the bridge ip as a radius client so the nps service will authenticate the clients. Not a big deal but a hassle. -
The other problem is my print management server is not able to connect to the printers on satellite sites, still have not found a way to fix that.
And the same leads to 3CX not being able to upgrade phone firmware over the sd-wan as it can not contact the phone ip directly as it can not see it.
I am using the zone based firewall setup and traffic between sites is not being blocked in any way I can see.
If anyone knows a way to change this gw ip instead of local ip showing I would appreciate the help ![]()
