Hi,
I have a unifi controller setup on an oracle ampere vm (supports 6 sites), i installed it a while ago using a script from here…
But i think unifi no longer supports this method as running apt upgrade gives the following error…
Skipping acquire of configured file ‘ubiquiti/binary-arm64/Packages’ as repository ‘https://www.ui.com/downloads/unifi/debian stable InRelease’ doesn’t support architecture ‘arm64’
Can i just install the deb file from here (and remove the repo from apt without it breaking) …
https://dl.ubnt.com/unifi/7.5.176/unifi_sysvinit_all.deb
over the current setup or will it break everything?
Thanks
Linux version: Ubuntu 20.04.6 LTS
Running mongod --version gives…
db version v3.6.8
build environment:
distarch: aarch64
target_arch: aarch64
Running: java --version gives…
openjdk 11.0.20.1 2023-08-24
OpenJDK Runtime Environment (build 11.0.20.1+1-post-Ubuntu-0ubuntu120.04)
OpenJDK 64-Bit Server VM (build 11.0.20.1+1-post-Ubuntu-0ubuntu120.04, mixed mode)
