great about the FQDN i have the domain unifi.mydomain.com in the old VPS how you suggest me to do this change and use the same FQDN in the new VPS?
DAMN!! There was an error generating a site export file. Backup failed.
this looks to be the same issue you are having
Yep an without any solution… ![]()
well he did say that he restarted and it worked after haha
UPDATE1: I notice that in one site i can do the Site Export option in the others no…
definitely export that site and maybe create new sites for the ones that are not exporting with the same settings on a new controller then just set-inform to the new controller. Only thing i can think of now.
@sysman923 what if i move the data directory from the old VPS to the new VPS…
UPDATE 2: i was able to migrate the AP to the new controller!!!
But in the process for some reason one AP was left behind in the site Export Process is there a method to force that AP to migrate to the new controller?
Update 3: Rogue AP migrate to new Controller!!
[Solved] Solution to the initial topic is migrate to a new Controller so far.
yeppp easy peasy. glad you found a solution
