I got a Unifi AP Pro a little over 6 months ago and I feel like I am having tons of problems. Speed is dreadfully slow sometimes without any real reason I can think of.
My previous router an ASUS black knight did not have bandwidth issues with the same devices connected.
I recently decided troubleshoot, it appears that the 2.5 band was being overloaded. I removed some devices from Wifi completely. Esp one of my TVs. but still it was showing 85% TX.
I thought to separate the 2.5 and 5 ghz networks so I can decide what devices are on what band. that option wasn’t available in the 5.9 controller software so I decided to downgrade the version I was running in docker.
I was able to set-defult and then set-inform to the new docker address without issue. But realized the option to combine or separate the bands was not there. I let is run for a while on that controller version to see if maybe there was a version issue but performance did not improve.
so again, I ran set-defult. started my original controller docker and it will not adopt. I have set-defult, set-inform, syswrapper.sh restore-default then set-inform again.
I even pressed and held the reset button for 30 seconds multiple times.
I am able to SSH into the device still but It will not adopt to my controller.
I am starting to think I have a defunct device. Are there logs I can pull to see what is happening? Any advice?
