Hi,
every time that there is a power outage (or if I simply unplug/replug the access point), in the UniFi network console I see the AP with status Adoption Failed.
I can connect to the AP (and from there to the internet), and I can ssh into the AP, but I can’t manage the AP.
I end up factory resetting and readopting the AP, but there’s probably something I’m doing wrong.
Does anyone have any idea as to what can be going on?
Context:
I am using UniFi Network console 7.3.83 on a Debian 11 VM.
I have connected the UAP-AC-Pro to a trunk port in the switch (with VLAN 5 as default, which I only use for console to AP traffic).
I access the web console through another VLAN (the VM sees 2 different interfaces, but they’re actually on the same wire, using different VLANs).
The DHCP server is directly connected to VLAN 5 and it correctly assigned an IP to the factory reset AP.
I was able to “adopt” the AP from the console.
I created 2 WiFi networks (aside from the one created during the console setup), both with “Third-party Gateway” (since I don’t have a UniFi Gateway).
