Hello,
I am trying to figure out if I need the AI port for 3rd party cameras within Protect.
My understanding is that for 3rd party cams, Protect won’t even read common triggers like motion because of the way different devices communicate. The Unifi Port/Key protects offloads the AI functionality from the cameras despite the cameras’ ability to do it itself. I understand that Protect/UNVR do not process that information either because the Unifi cams do it themselves.
If Synology does all the processing on it’s hardware then what’s the point of using $200+ AI cams with Synology?
When you factor in the cost of the AI keys or Synology cam licenses, I’m having a hard time convincing a friend not to use Amcrest NVR with something other than it’s crap.
There’s gotta be a way to pull that data from the camera, are the vendors using their own proprietary languages??
This is frustrating. We are so close to the perfect system.
