After I rebooted PFS I cannot make cahnges to the LAN due to the bfollwoing error:
The DHCP6 Server is active on this interface and it can be used only with a static IPv6 configuration. Please disable the DHCPv6 Server service on this interface first, then change the interface configuration.
The Router Advertisements Server is active on this interface and it can be used only with a static IPv6 configuration. Please disable the Router Advertisements Server service on this interface first, then change the interface configuration."
I looked for a solution on Netgate and other and the solution is nort working for me " Temporarily enable IPv6 on your LAN interface and set IPv6 Configuration Type to “Static IPv6”, then assign it an IPv6 address (“::1” without quotes works with mask /128). Then Save.
2. Go to Services/DHCPv6 Server & RA/LAN/Router Advertisements then set Router Mode to “Disabled”. Then Save.
3. Go back to the LAN interface and set IPv6 Configuration Type back to “None” then Save."
Does anyone have a solution?
