UDM with a Firewall
Hello,
I have the following question about UDM Pro (Max).
My setup:
Internet access ↔ Firewall ↔ Switch (Core) ↔ Switch (Access, Unify) ↔ UDM Pro Max.
  • UDM WAN interface (own dedicated VLAN) → Switch
  • UDM LAN interface (our default VLAN) → Switch
1. We have disabled NAT on UDM.
2. Unfortunately, the LAN interface always uses the same VLAN as the WAN.
Any ideas? Is this okay, or is there a better solution? We do not plan to purchase additional hardware.
UDM should not route, firewalling etc. I want to add some Access Devices from Unify
@brwainer I appreciate your posts you did regarding UDM. Can you help me?
What is the goal? Why have the UDM if you are not going to use NAT or routing?
