I am looking to setup a network in my home using unifi products, I currently have some unifi access points, 1 x AC Pro 2 x U6 Pro. These are currently working in standalone mode using the poe injector.
If I purchase the UDM SE will the below points work ?
access points connect directly to the console, using the poe on board?
There are oddities on the UDM Pro and UDM SE, as it pertains to the switch and ports. The switch has a single 1Gbps channel to the CPU (might be 2.5Gbps?), so it’s not a good switch for higher bandwidth usage.
I would use SFP+ on the WAN side and/or on the LAN side. Avoid the switch on the UDM Pro/SE. It’s fine for low bandwidth items such as a handful of cameras or phones, but would not put access points on them. Think of the UDM Pro/SE as a device without the 8 switch ports, for networking infrastructure.
