Good day there, I am absolutely stumped here trying to find where to disable the SIP encryption in a UCG Ultra gateway. Does any one have any in site on this?
login to the router, Routing & Firewall, Firewall tab, Settings, SIP off
Assuming you’re on a current version of the OS and Network Application, it should be at Settings > Routing > NAT > Firewall Connection Tracking (bottom of the page). In that box, if it doesn’t show “SIP” then the routing is treating SIP as any other type of connection and not doing any changes to it.
I’m assuming that’s what you mean, because there is no SIP “encryption” in the Unifi gateways.
