Ubiquiti Unify - Newer Firewall/Router
Hello all,
Was looking to see if the newer Unifi “Firewall” supports IP blocks routed through WAN1/WAN2 connections? Right now we are using Netgate/pfSense. We have the IP block bypassing NAT. It is also routed through the /30 provided by the ISP. Is this possible on Unifi? Also is it possible to limit speeds like on the pfSense? I can limit them now by the port/network via pfsense.
Yes, you can work with routed public IPs. You can completely disable outbound (masquerade) NAT or make custom rules for which downstream networks get outbound NAT and to which IP they are mapped.
There are newer options for applying speed limits but they may not map exactly to what you have currently. Best is to get a cheap demo unit like a UCG-Ultra and test it out. All the features are the same unless you’re trying to do TLS decryption.
Does it support Hybrid and Manual NAT for outbound?
It doesn’t use those terms but basically yeah. The documentation is here: https://help.ui.com/hc/en-us/articles/16437942532759-DNAT-SNAT-and-Masquerading-in-UniFi Hybrid NAT is closest to doing the Global NAT > Custom option with some networks selected, and Manual NAT is just going the step forward to have no automatic NAT rules (Global NAT > Off) and making all the SNAT/DNAT/Masquerade rules manually. You should test it before committing to it though.
honestly the new router does let you turn off the global masquerade and set per network limits but the UI is still a bit clunky and you may need to script some of the finer QoS rules
