questions. i have a customer that do have one dream machine Pro with network controller and protect. at another site they want more cameras and a new firewall, i am thinking of adding a gateway here and maybe an UNVR for the cameras.
Is it possible to se both sites in one unifi protect app on the phone?
aka 2 sites, two unifi protect hardware, se both in same app..
I’m not 100% sure but if you have a UniFi cloud account and have your devices added in the cloud then you can view them all in a single pane of glass.
But I’ll defer to someone who knows more than me.
On unifi.ui.com you can use the Vantage Point feature to connect to multiple NVRs at the same time and view whatever combination of cameras you want, and access all their recordings.
Once you make a Vantage Point group on the website it will show up in the app in the dropdown selector for NVRs.
You need Vantage Point
https://help.ui.com/hc/en-us/articles/27719500615959-UniFi-Vantage-Point-Multi-NVR-Camera-Management
Vantage point looks exactly like the thing i whant, thanks.
and if i do not understand wrong i could use two UDM Pro for this? or any hardware running protect?
Only certain devices will run protect, you need to look at the tech spec for each device,
Yes, any of the Dream Machines can run protect
