Hi
I have a WiFi bridge between my house and office using 2 ubiquiti nanostation loco M2’s. It’s worked perfect for 3 years.
I moved my office and the Station receiver to a new location but the issue is I am not getting any power to it via the 24v poe injector.
Only difference in 2 locations is length of cable from Poe to the nanostation. Old office it was 10 ft and new office is 35ft.
Does the power drop off with a longer run on these older nanostation devices?
As a test I plugged in a Unifi AC lite ap and it works. I also tried a 48v Poe injector and no luck.
Do I need to shorten the run from poe to the nanostation?
Thanks for any advice
