Two-bay NAS with an N100 for photos and movies — is the DXP2800 enough for a mixed library?
I have a two-drive setup at home for photos, a music collection and some movies, and I am trying to decide whether a small two-bay NAS is the right next step instead of keeping everything on an external drive. The appeal is having one box that can stream to the TV and let a couple of family devices browse files without a desktop running.
What I am unsure about is whether the N100 chip handles transcoding when a client cannot play the original file, or whether that job falls apart on bigger files. I also have no idea how UGREEN’s software compares for simple photo backup and shared folders, since I would rather not spend evenings fiddling with settings.
I have been reading the UGREEN NASync DXP2800 Review: 2-Bay Intel N100 NAS for Home Media, which matches the size I am looking at, but I still cannot tell if two bays is too limiting once drives fill up.
How does this one behave for mixed media libraries and simple sharing in a normal home setup?
This is a big issue you are going to run into right off the bat. The only option you have at that point is to transcode your movies into the proper format your TV’s or streaming devices so it runs direct or you are going to have a bad day.
This all comes down to planning. If you or others like to take lots of videos and pictures then plan on buying bigger hard drives for storage. If you plan on putting a lot of 1080P movies on there too you are looking at about ~15-20GB per movie unless you transcode them into something smaller.
For me I start this journey on an old PC that had 4 sata ports on it running freenas 8, 10 years ago. I had 4 - 3TB drives then later on had to expand to 8 drives (RAIDZ-2). I am running the latest Truenas today. Now I need to expand again, but hardware is so expensive in this point in time.
I don’t know your situation, but at least for me the right call was to get decent hardware so you can have the flexability to pivot to support something. In this case transcoding can be solved with a intel Ark GPU (Or a CPU that has a built in GPU). TrueNAS is pretty flexible with containers for your apps and you can’t beat ZFS for data integrity.
I understand the ugreen device is compact and it might be a fit for you, but I think the better option is spending a little bit more for expansion and flexibility in the future then having a paperweight 3 years from now.
If you want an all-in-one box then just look for one with a more powerful processor.
As said the prices for hardware is just going in one direction, what I would do is to to buy one of those 1 litre tiny pcs from Lenovo second hand, install Proxmox and whatever software you want. Plugin some USB drives and you’re good to go. If you later want to buy a NAS, crack open the USB drives and just plug them in, the Lenovo box is handy for little projects.
I have an 8 bay QNAP NAS from 10 years ago, it’s still going, but I have a backup USB bays plugged into PROXMOX. I doubt I can afford to pay for the same equivalent gear at the current prices.
The UGREEN boxes get good reviews. But if it was me I would go with a 4 bay minimum, and really would prefer a 6 bay. I started out with a two bay, sold it and quickly updated to a 4 bay, then a 6 bay where I have been sitting for a quite a while. I only use 4 of the 6 bays currently, leaving me room to expand.
If you can afford the upgrade, the UGREEN NASync DXP4800 Pro seems like a really nice unit.
