TrueNAS Scale: Unable to delete bond0
I’ve been experimenting with networking on scale and bound my 10GbE and 2.5GbE together in a fail over “bond0” and it works fine.
Now I want to delete it and return the configuration to two individual NICs.
I’m doing this:
  1. Delete bond0
  2. Configure enp1s0
  3. Configure enp4s0
  4. Test changes
I lose the connection and it returns after the timeout.
How do I “undo” adding the bond? Is there some kind of undocumented procedure?
What version of scale are you on. are there any apps installed? This will help answer the question better.
Version 24.10 is installed and I have installed no apps either.
If you can hook a monitor up to the machine the CLI is the easiest way I found to change this.
Use the local console and the text menus, reset networking and build from scratch.
Sorry for not responding sooner. I was able to remove a NIC from the bond, then delete the bond and then it locked me out. I had to restart for the configuration to load.
Thanks for the help and advice.
