I’m not able to create a pool on TrueNAS Scale.
I’m running TrueNAS scale as a VM inside Proxmox. I have passed through two HDD (WD RED 4TB x 2) via scsi that I intend on setting up as a Raid10 ZFS (4TB).
When I go to Create Pool,
I select both drives under a vdev, set to mirror. I’ve filled out the name field and click Create Pool.
The “Create Pool - Fetching Data…” popup opens and stays on “Fetching Data”. It doesn’t create a pool.
The things I’ve tried:
- Waited 1+ hour on “Fetching Data” screen
- I added a single GPT partition via fdisk on each drive
Anyone know where I went wrong?
Any suggestions on what I could try next?
Thanks in advance.
