Hi all,
I was previously running the TrueCharts version of NextCloud on TrueNAS scale, but I’m tired of them making breaking changes every other update.
Decided to try following Tom’s guide for setting up the official image in Scale, and I keep running into issues.
I’ve created 2 datasets - one for data, the other for the database and assigned permissions as Tom did.
However when the container starts it keeps getting stuck on “Deploying 1/2” and never progresses, even if I leave it for 30+ minutes.
The event logs shows this message “Liveness probe failed: Get “http://172.16.80.63:80/status.php”: dial tcp 172.16.80.63:80: connect: connection refused”
Based on the message it sounds like there’s no webserver listening where the container is expecting there to be one, but I have no idea where to go about troubleshooting this. I’ve double and triple checked that the owner and group of the nextcloud data dataset are www-data and have full read-write permissions.
Anyone run into this before, or should I go bother the folks on the IX systems forums?
