Hey Folks
After years of pulling my hair out with Freenas & Truenas Core, I installed Truenas Scale on my Proprietary Hardware and It runs like a Dream!!
FQDN for NAS and Plugins - Check
Resolving to Address - Check
Gave up on HA Proxy for SSL, Just couldn’t work it out, So used the ACME DNS-Authenticators via Cloudflare API which worked straight away. Incidentally, that is how Truenas recommend your SSL settings.
Now the problem I am having with Nextcloud is, I can’t go into the Jail like in Core to edit the PHP file. The FQDN resolves to the internal IP so I need to edit that and resolve these warnings below.
- Your web server is not properly set up to resolve “/.well-known/caldav”. Further information can be found in the documentation
. - Your web server is not properly set up to resolve “/.well-known/carddav”. Further information can be found in the documentation
. - Your installation has no default phone region set. This is required to validate phone numbers in the profile settings without a country code. To allow numbers without a country code, please add “default_phone_region” with the respective ISO 3166-1 code
of the region to your config file. - Module php-imagick in this instance has no SVG support. For better compatibility it is recommended to install it.
If somebody could be so kind as to advise me on what to do it would be appreciated.
Please, Provide the exact code to write as I’m not too good at that!.
Kindest regards
James
