Truenas Scale Local IP accesibility
Hello,
I have a problem with my TrueNAS scale server, a few updates ago the server stopped responding to the local IP address 192.168.14.20. Except from MacOS no other machine can connect to the webinterface or SMB or anything.
With tailscale i can connect everything, no issues there but on any Windows machine anything related to the local IP does not work.
I scoured the internet for the answer but none of them seem to work.
The configuration is standard
Interface:
enp0s31f6 - static ip 192.168.14.20/24
Nameservers
Nameserver 1: 192.168.14.1
Default Route
routerIPv4:
  • 192.168.14.1
  • Hostname:truenas
  • Domain: Inherit from DHCP
  • HTTP Proxy:—
  • Service Announcement: NETBIOS-NS, mDNS, WS-DISCOVERY
  • Additional Domains:—
  • Hostname Database:—
  • Outbound Network:Allow All
I am a noob when it comes with TrueNAS CLI.
Thank you in advance
That does not really sound like a TrueNAS issue unless you have gone to System → Advanced Settings and set the Allowed IP Addresses option.
Did you try manually typing both http and https to see if one worked and the other did not?
