Hello just wondering if anyone has had to expand the storage for a virtual machine in truenas scale yet. If so any tricks or just go to the dataset and increase the storage. Also the vm is ubuntu 22.10 server what needs to be done on the vm side to properly resize the disk thanks
Not something that I have tested but it should be just a matter of expanding the ZVOL then expanding the Linux partition.
Ok i will give it a try thanks for the info
