Okay techies got a question for those that have run into this exact problem.
Running 2 instances of Truenas:
1-Truenas Core running bare metal on a Supermicro with an Intel Xeon and On board Intel Graphics, ECC etc. It’s a server-based board.
1-Truenas Scale running inside Proxmox on another Supermicro board with hardware pass through and no issues, other than I need to manually start it versus automatically starting. Not a big deal as this is mostly a backup/r-sync machine.
Now when I tried to install Truenas Scale Electric EEL, Dragonfish, on the bare metal, I continually got “boot pool import” error then drops to (initramfs).
I double checked my SSDs for overall health, read, write and for errors. They are clean, at least by the software they show clean and healthy. I even deleted and wiped the partitions on both of them after doing the drive integrity check.
At one point I was able to get the installation to boot after some command line examples I found, but then I started getting the EDID 0 error based on the iGPU and i915 driver issue. I made appropriate changes, yet that issue continued to prop up on the console.
I disabled just about everything for the Intel GPU leaving only the ASPEED chip for display.
This is part of the reason I stuck with Core, because, well it just works out of the box. This is the second attempt at trying to run Scale on a bare metal, and it hasn’t worked out to well for me anyways. Now virtualized Truenas Scale works, which boggles me.
This was brought up in the iX Systems bug tracker and was supposedly addressed, but there are other examples of people continuing to run into this even after they acknowledged it to this day.
Any ideas and experiences on installing Truenas Scale without having to address these issues?
From BIOS settings to UEFI parameters.
Command line input
Etc.
I have nothing but respect for iX and the software, yet CORE works, Scale Continues to be buggy. I would like to have a bare metal running Truenas Scale since they are deprecating Core, but it’s the same issues after Scale first came out.
Thanks
