I am trying to sync a windows machine to a truenas scale dataset. I followed Tom’s
" How To Setup TrueNAS Scale Apps With Shares For Host Path Volumes".
I just want the windows folder to be backed up to truenas. I wanted to set it so windows box sends only and the truenas only receives but I do not set up right now.
In windows
syncthing
the windows machine gets stuck at Syncing (12%, 8g6 B) in the remote devices sections, the “Folders” is up to date.
In truenas
syncthing
the “Folders” is out of Sync
with failed
“syncing: handling dir (setting permissions): chmod /file_path operation not permitted”
HOWEVER
I look at the folder on the truenas via smb the files are there.
when I ssh into the box and
when I ls -la
drwxrwxrwx 2 apps X201 2 Jan 18 05:25 ‘New folder’
Thank you for the response, I really do appreciate it.
The dataset was set to
Owner: apps
Group: apps
I got it working, but not sure how “correct” the solution is. On the truenas forums a post says to change “‘aclmode=passthrough’” and that indeed fixed it.
Honestly, not sure what switching that fixes or breaks. Can anyone tell me what I have wrong from changing “‘aclmode=passthrough’”?
I have not been keeping up with all the recent changes to their apps as we don’t use them in production environments and while I did the demo on Filebrowser, it’s not part of my daily use to know what changed.
