I am trying to import an existing pool into Truenas Core that originated as a Truenas pool. The data is just for testing. I have been able to import the pool and can view the data in the pool when viewed from the CLI. The issue is when I add permissions and share the pool as an SMB share, I receive “you do not have permission to access” from Windows. I have been able to follow the video “TrueNAS Core: Configuring Shares, Permissions, Snapshots & Shadow Copies” and know this was talked about. Even when I log out and back into windows I get the same error. If I test with a different pool that I create I can mount the SMB share without an issue.
I would like to see if there are any specific items that need to be addressed when adding an existing pool. I’m trying to do it without a config file to see if this can be done. Since I see the data via the CLI, I know its there and I could copy it via SFTP but would like to see why an SMB share continues to fail.
