TrueNAS Hardening Guide 2026
TrueNAS Hardening Guide: Step-by-Step Security
This guide covers the essential steps for securing your TrueNAS deployment and ensuring your data remains resilient against both hardware failure and malicious actors.
1. User Management, SSH, and Web Interface
On setup TrueNAS had you create an alternative admin but you can create others as needed because each admin should have their own login. You can also create read only or share management admin log in’s. New admins must have a home dataset on the pool. Simply creating a dataset called home will work for that.
  • Create a Custom Admin:
    • Menu: Credentials -> Users -> add
    • Create a new user and assign them the choose their TruerNAS Access role
    • Add SSH key if needed
    • Choose the home on /mnt/ and check the Create Home Directory box and leave the permissions box checked
    • These permissions also apply to API keys created under those users
  • Disable root User (if enabled)
    • root was the default user for older installs and does not get disabled with standard in place upgrades
    • Menu: Credentials > Users
    • Create a new admin account
    • Once your new custom admin is verified and working, edit the root and admin accounts to disable their passwords. This prevents brute-force attempts on the most targeted usernames.
  • Enforce Two-Factor Authentication (2FA):
    • Menu: System Settings > Advanced > Two-Factor Authentication
    • Enable Global 2FA. This forces all UI logins to require a TOTP code (e.g., Google Authenticator or Aegis).
  • Console Protection:
    • Disable “Show Text Console without Password Prompt.” This prevents someone with physical access from using the monitor/keyboard to reset your admin password or reconfigure networking.
2. Network Hardening
Control how and where your TrueNAS instance communicates on the wire.
  • Web Interface Binding:
    • Menu: System > General Settings > GUI
    • Bind web interface to management interface
  • HTTP to HTTPS Redirect:
    • Menu: System > General Setting > GUI
    • Ensure “Web Interface HTTP → HTTPS Redirect” is enabled so all management traffic is encrypted.
  • Allowed IP Addresses:
    • Menu: System > Advnaced Settings > Allowed IP Addresses
    • Use the “Allowed IP Addresses” field to whitelist only specific management workstations or subnets that are allowed to access the login page.
  • Disable Unused Services:
    • Menu: System > Services
    • Audit your services. If you aren’t using iSCSI, NFS, or FTP, ensure they are toggled OFF to reduce the attack surface.
  • Bind Services To Interfaces
    • Do not let services listen on all available ports. Bind them only to the interfaces where they will be used
  • Set Host Allow and or Deny for Shares
    • Menu: Shares
    • Each share can be set to allow or deny based on IP
3. Secure SSH Configuration
If remote shell access is required, eliminate password-based vulnerabilities.
  • Public Key Authentication:
    • Menu: Credentials > Users > [Your User] > Authentication
    • Generate an SSH key pair on your local machine and upload the Public Key to your user profile.
  • Disable Password Auth & Root SSH:
    • Menu: System > Services > SSH (Settings)
    • Uncheck “Allow Password Authentication.”
    • Ensure “Allow SSH Password Login for Root” is disabled. This forces the use of cryptographic keys.
4. Data Protection & Maintenance
Hardening is useless if the data is lost to hardware failure or accidental deletion.
  • Dataset Encryption:
    • Menu: Datasets > [Add/Edit Dataset]
    • This is done at the creation of the dataset and it can not be converted after creation to or from being encrypted
    • Use AES-256-GCM encryption for sensitive data.
    • Full Video on TrueNAS Encryption https://youtu.be/Ic8vZx3QBew?si=PO8-X68V8kPpg1m-
    • Pro Tip: Do not set the “Inherit” flag if you want individual control over which datasets remain locked until manually authorized after a reboot.
  • Automated ZFS Snapshots:
  • Backup TrueNAS Configuration:
    • Menu: System > Advanced Settings
    • Your ZFS pools hold your data, but your Config File holds your users, permissions, and network settings. Download a fresh backup of this file after every major configuration change.
  • ZFS Scrub
    • Schedule a pool Scrub every 2–4 weeks to detect and repair data corruption (bit rot).
Thank you for your guide and video!
Which of the security settings listed above are effective if a malicious actor gains physical access to the TrueNAS box?
The only thing that helps is to disable “Show Text Console without Password Prompt”
Is that correct?
If someone has physical access and you are worried about your data you should be using a passphrase on those datasets.
Hi,
I would like to ask about the SSH connection user for remote replication.
In this video, Backup & Recovery Made Easy: TrueNAS ZFS Replication Tutorial, you show how to create a connection using the wizard. You used admin credentials to connect to another server and root credentials for the SSH connection.
I understand that the root is being deprecated in newer versions, so not sure if it is still possible to do it that way. But following the tips from this video, Backups, Virtual Air-Gaps, and TrueNAS Replication Setup | TrueNAS Tech Talk (T3) E058, I have decided to create a separate user just for pull replication.
This replication_user has only SSH enabled, the password is disabled and uses an SSH key instead. But I believe it also had to have allow sudo commands without password /sbin/zfs, sbin/zpool.So “Use Sudo For ZFS Commands” will work when creating a replication task.
I will still create a connection using the truenas_admin credentials. But keep connected using replication_user.
Does that seem right?
Thanks!
The root user has been deprecated for the web interface log in but still can be used for doing ssh key only for replication. I have not tested trying to use a user in the sudo list to see how that will work.
