I’m just starting to tinker with S3 in TrueNAS and could use some guidance with certificates. Is there a tutorial showing how to create a new certificate to use with TrueNAS S3 service?
My only experience with certificates is with Nginx Proxy Manager, and it basically does the whole thing for you.
I don’t have a guide on it but you can use the certificate manager in TrueNAS to create a new one.
Do you guys recommend installing the full version of MinIO for S3 usage? It appears that the integrated version is limited to only 1 account.
Depends on your needs, but you can install MinIO in a container if you have a need for more.
