I just upgraded from 11.3 U4 to 12.0 RC1 and now my windows pervious versions don’t show any.
I had shadow copies set up on FreeNAS 11 before and they worked. Since the upgrade they seam to have disappeared. I tried to delete the old snap shots and create new ones but when I go to advanced and enable shadow copies there is no drop down anymore to point them to the snapshot location. I tried to un-enable SMB and then re-enable it and still no luck.
Do I have to delete the shares and re-create them?
I did upgrade my pools to 12.
