TrueNAS Consumer VS Enterprise Drives for ZFS LOG
:wrench: Basic Overview
Feature Intel SSD DC P3700 WD Black SN850 NVMe
Interface PCIe 3.0 x4 (U.2 / HHHL AIC) PCIe 4.0 x4 (M.2 2280)
Protocol NVMe 1.1 NVMe 1.4
NAND Type Intel HET (High-Endurance Technology) MLC 3D TLC NAND
Capacity Range 400GB – 2TB 500GB – 2TB
Release Year ~2014 ~2020
:high_voltage: Performance
Metric Intel DC P3700 (1.6TB) WD Black SN850 (1TB)
Sequential Read ~2.8 GB/s ~7.0 GB/s
Sequential Write ~2.0 GB/s ~5.3 GB/s
Random Read (4K, IOPS) ~450K ~1M
Random Write (4K, IOPS) ~150K ~720K
:shield: Endurance and Reliability
Spec Intel DC P3700 WD Black SN850
DWPD (Drive Writes Per Day) 17 DWPD (for 5 years!) ~0.3 DWPD
TBW (1TB model) ~12.3 PB 600 TB
Power Loss Protection Yes (enterprise-grade) No
MTBF 2 million hours 1.75 million hours
:bar_chart: Queue Depth Capabilities
Max Queue Depth (per NVMe spec) Up to 128 queues x 64K commands Up to 64 queues x 64K commands
Optimized for High QD, consistent latency Low–mid QD, high peak throughput
FIO command used for Testing
sync;fio --randrepeat=1 --ioengine=libaio --direct=1 --gtod_reduce=1 --name=test_rand_write --filename=test_rand_write --numjobs=32 --bs=4k --iodepth=256 --size=200M --readwrite=randwrite --ramp_time=4 --group_reporting
sync;fio --randrepeat=1 --ioengine=libaio --direct=1 --gtod_reduce=1 --name=test_seq_write --filename=test_seq_write --numjobs=32 --bs=4k --iodepth=256 --size=200M --readwrite=write --ramp_time=4 --group_reporting
Results Using as ZFS LOG with Sync=Always for Dataset
Random Write 330MB/s IOPS=80.0K 178MB/s IOPS=43.1k
Sequential Write 350MB/s IOPS=84.9K 145MB/s IOPS=35.1k
:brain: But WHY?
Both drives technically support high NVMe queue depths (64K commands per queue × multiple queues), but:
  • Intel’s controller and firmware are tuned to make actual use of deep queues efficiently.
  • WD’s SN850 controller (SanDisk/WD G2) is built for bursty I/O and throughput, not sustained parallel workloads.
:thread: Summary
If your workload regularly pushes queue depths above 32, the P3700 will outperform the SN850, even though the SN850 has better raw specs on paper. In homelabs or servers, queue depth can be the secret sauce — and that’s where the P3700 shines.
Other videos for reference
Explaining ZFS LOG and L2ARC Cache: Do You Need One and How Do They Work?
ZFS is a COW
Understanding ZFS in the Real World: Mistakes Made, Lessons Learned & Future Plans
