Admitted neob. I had a drive in my TrueNAS box that needed to be replaced. I did so with a like and kind WD 4TB drive. I’ve re-silvered and scrubbed the pool. When running the command ‘zpool status ’ I’m getting the following report:
root@truenas[~]# zpool status data
pool: data
state: ONLINE
scan: scrub repaired 0B in 03:02:02 with 0 errors on Tue Jul 30 09:17:09 2024
config:
NAME STATE READ WRITE CKSUM
data ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
sdd2 ONLINE 0 0 0
sdg2 ONLINE 0 0 0
sdi2 ONLINE 0 0 0
1e876aba-c845-48bc-8b09-811ee04507b8 ONLINE 0 0 0
sdj2 ONLINE 0 0 0
sdk2 ONLINE 0 0 0
sdc2 ONLINE 0 0 0
sdb2 ONLINE 0 0 0
logs
sdf1 ONLINE 0 0 0
errors: No known data errors
I’ve done a reboot of the machine after the last scrub and ran the above zpool command after the reboot.
Is the drive that is reporting a system ID rather than the ‘sd??’ label concern me? All other UI reports are showing the drive as sdg.
TIA for any clues.
