Truenas 25.10 disk throughput is abysmal- Tom I hope they will listen to you
Tom:
I started using both TrueNAS and XCP-NG because of you. You have always been very helpful and informative and I appreciate all you do.
Over on the TrueNAS community forum, I made a post in the beta cycle that TrueNAS 25.01 was extremely slow compared to previous versions. The post went mostly ignored.
Last week, when 25.01 was released, I ran the same tests and confirmed it is still a problem. I made another post…crickets.I posted a bug report but they closed it saying it was something to do with: “Disk utilization not being reported properly” and “Excessive reported disk throughput” (neither of which seems to make sense??).
I’ve now checked six different installations, the reduced speed is in all of them.
For the heck of it, wondering if the issue was with upgrading from one version to another, last night I set up two different brand new installs; one with 25.04.2.6 and one with 25.10. Both have identical specs. Both were installed with the defaults.
25.10 data storage speeds are massively lower than 25.04.x.
In the end, I’d love it if y’all could conform what I’m seeing but also hope that, they will listen to you since you have been a huge supporter of theirs.
Thanks!
My original post is shown below.
I have two locations where I have upgraded TN 25.04.2.3 to 25.10. In both instances the drive performance has dropped through the floor. In some instances it has dropped as much as 98%. I had this same issue during the beta and reported it then.
One machine is a bare metal and one is a virtual machines (XCP-NG): the virtual one is running to a passed through LSI controller. Both have worked great since version 22xxxx.
Shown below are the tests from FIO (Flexible I/O Tester).
The drives below are all SATA drives but the same holds true with SSD drives.
Any ideas?
Thanks!
Computer #1
Processor Intel(R) Xeon(R) CPU E5-2695 v4 @ 2.10GHz (bare metal)
RAM 62.8 GB
VDEV type RaidZ2
SLOG SDD
TESTS
Random write test
test: test: (g=0): rw=randwrite, bs=(R) 1024KiB-1024KiB, (W) 1024KiB-1024KiB, (T) 1024KiB-1024KiB, ioengine=libaio, iodepth=32
Before WRITE: bw=1321MiB/s (1385MB/s), 1321MiB/s-1321MiB/s (1385MB/s-1385MB/s), io=4096MiB (4295MB), run=3101-3101msec
After WRITE: bw=76.1MiB/s (79.8MB/s), 76.1MiB/s-76.1MiB/s (79.8MB/s-79.8MB/s), io=1728MiB (1812MB), run=22698-22698msec
Decrease -94.0%
Random Read test
test: (g=0): rw=randread, bs=(R) 1024KiB-1024KiB, (W) 1024KiB-1024KiB, (T) 1024KiB-1024KiB, ioengine=libaio, iodepth=32
Before READ: bw=1531MiB/s (1606MB/s), 1531MiB/s-1531MiB/s (1606MB/s-1606MB/s), io=4096MiB (4295MB), run=2675-2675msec
After bw=50.0MiB/s (52.4MB/s), 50.0MiB/s-50.0MiB/s (52.4MB/s-52.4MB/s), io=573MiB (601MB), run=11466-11466msec
Decrease -97.2%
Mixed Random Workload test
test: (g=0): rw=rw, bs=(R) 1024KiB-1024KiB, (W) 1024KiB-1024KiB, (T) 1024KiB-1024KiB, ioengine=libaio, iodepth=32
Before READ: bw=1170MiB/s (1227MB/s), 1170MiB/s-1170MiB/s (1227MB/s-1227MB/s), io=1992MiB (2089MB), run=1703-1703msec
After READ: bw=50.0MiB/s (52.4MB/s), 50.0MiB/s-50.0MiB/s (52.4MB/s-52.4MB/s), io=573MiB (601MB), run=11466-11466msec
Decrease -95.7%
Before WRITE: bw=1235MiB/s (1295MB/s), 1235MiB/s-1235MiB/s (1295MB/s-1295MB/s), io=2104MiB (2206MB), run=1703-1703msec
After WRITE: bw=53.7MiB/s (56.3MB/s), 53.7MiB/s-53.7MiB/s (56.3MB/s-56.3MB/s), io=616MiB (646MB), run=11466-11466msec
Decrease -84.14%
Sequential write test
test: (g=0): rw=write, bs=(R) 1024KiB-1024KiB, (W) 1024KiB-1024KiB, (T) 1024KiB-1024KiB, ioengine=libaio, iodepth=32
Before WRITE: bw=1547MiB/s (1622MB/s), 1547MiB/s-1547MiB/s (1622MB/s-1622MB/s), io=4096MiB (4295MB), run=2648-2648msec
After WRITE: bw=98.1MiB/s (103MB/s), 98.1MiB/s-98.1MiB/s (103MB/s-103MB/s), io=290MiB (304MB), run=2955-2955msec
Decrease -93.7%
Sequential Read test
test: (g=0): rw=read, bs=(R) 1024KiB-1024KiB, (W) 1024KiB-1024KiB, (T) 1024KiB-1024KiB, ioengine=libaio, iodepth=32
Before READ: bw=1610MiB/s (1688MB/s), 1610MiB/s-1610MiB/s (1688MB/s-1688MB/s), io=4096MiB (4295MB), run=2544-2544msec
After READ: bw=244MiB/s (255MB/s), 244MiB/s-244MiB/s (255MB/s-255MB/s), io=4096MiB (4295MB), run=16811-16811msec
Decrease -84.8%
Computer #2
Processor Intel(R) Xeon(R) CPU E5-2450 0 @ 2.10GHz (Virtual)
RAM 16 GB
VDEV type RAIDZ1
SLOG NVME
TESTS
Random write test
Before WRITE: bw=229MiB/s (240MB/s), 229MiB/s-229MiB/s (240MB/s-240MB/s), io=4096MiB (4295MB), run=17884-17884msec
After WRITE: bw=189MiB/s (198MB/s), 189MiB/s-189MiB/s (198MB/s-198MB/s), io=4096MiB (4295MB), run=21641-21641msec
Decrease -17.%
Random Read test
Before READ: bw=1341MiB/s (1406MB/s), 1341MiB/s-1341MiB/s (1406MB/s-1406MB/s), io=4096MiB (4295MB), run=3055-3055msec
After READ: bw=64.2MiB/s (67.3MB/s), 64.2MiB/s-64.2MiB/s (67.3MB/s-67.3MB/s), io=2403MiB (2520MB), run=37417-37417msec
Decrease -95.2%
Before READ: bw=440MiB/s (461MB/s), 440MiB/s-440MiB/s (461MB/s-461MB/s), io=1992MiB (2089MB), run=4532-4532msec
After READ: bw=70.5MiB/s (74.0MB/s), 70.5MiB/s-70.5MiB/s (74.0MB/s-74.0MB/s), io=1992MiB (2089MB), run=28242-28242msec
Decrease -84.00%
Before WRITE: bw=464MiB/s (487MB/s), 464MiB/s-464MiB/s (487MB/s-487MB/s), io=2104MiB (2206MB), run=4532-4532msec
After WRITE: bw=74.5MiB/s (78.1MB/s), 74.5MiB/s-74.5MiB/s (78.1MB/s-78.1MB/s), io=2104MiB (2206MB), run=28242-28242msec
Decrease -83.90%
Before WRITE: bw=243MiB/s (254MB/s), 243MiB/s-243MiB/s (254MB/s-254MB/s), io=4096MiB (4295MB), run=16889-16889msec
After WRITE: bw=185MiB/s (194MB/s), 185MiB/s-185MiB/s (194MB/s-194MB/s), io=4096MiB (4295MB), run=22086-22086msec
Decrease -23.9%
Before READ: bw=1375MiB/s (1442MB/s), 1375MiB/s-1375MiB/s (1442MB/s-1442MB/s), io=4096MiB (4295MB), run=2979-2979msec
After READ: bw=405MiB/s (425MB/s), 405MiB/s-405MiB/s (425MB/s-425MB/s), io=4096MiB (4295MB), run=10109-10109msec
Decrease -70.5%
I have not noted any issues after updating my systems, please link to the TrueNAS forums post for reference. I should have some time to do some testing later this week.
Thanks Tom!
The link below is to the original post.
