Hey guys, I need help. I have a pfsense box that I would wish to setup up limiters on the LAN port, but the only problem is that I have a Three_WAN connection using it as Loadbalancing. I tried looking into the topic and even asking it on the Netgate forum but I have not had an answer. To be honest, I am still a NOOB in this area, kindly help
What is the overall goal you are trying to achieve with the connections? Are you trying to limit the speed of each host?
@LTS_Tom, yes I am trying to do that , mind you the pfsense is load balancing the three connections
You should be able to create them based on my CodelQ video https://youtu.be/iXqExAALzR8 but apply them to LAN. I have never set it up before though, good luck!
