Just a quick tip if you are using the EAP 245 access point with the Omada controller software, you won’t be able to monitor it with Zabbix over SNMP.
However, you can setup the AP initially setup SNMP with say Zabbix, then add the AP to the controller.
Clearly the AP supports SNMP but the controller does not. Noticed this while refreshing my Zabbix setup.
