Topology advice XCP-NG
Hi, and Happy New Year. Looking for some advice on the below:
I have 3 sites which are currently linked via IPsec VPN (A,B,C)
Site A) 2 x XCP-ng Hosts + TrueNAS NFS 10GB links shared storage NFS
Site A is working well and I am not running HA. I am looking to also setup site B and C with same hardware so 3 x NAS 6 x Hosts in total.
tbh not sure how I should setup sites B and C. Should I have just a single Master or 3 Masters and separate pools for each site.
Each NAS currently replicates to each other any advice is gratefully appreciated.
If it were me I would have a pool per site. Then if you need to scale at any site at a given time then you expand the sites pool. For management I would install a XO proxy on sites B and C.
One pool per site would be the proper way to set that up but you can still use on XO to manage all the sites so they are in one dashboard.
Many thanks, will do.
Not played with XO proxy will have a look.
