Tools for Penetration Testing VLANs and Firewall Rules
I recently upgraded my home router to a Ubiquiti Dream Machine SE and I’m working on setting up an isolated VLAN for some public facing web and game servers. So far I have some basic rules in place to disable inter-VLAN routing between the public VLAN and my private VLANs.
My public VLAN seems to be isolated enough, but I’d like to do some more in-depth penetration testing. Does anyone know of any tools or test suites that might help me verify that my public VLAN is truly isolated from my private VLANs? Maybe a test suite that would test configuration issues like VLAN hopping?
I use Nessus for pen testing. You can get a free activation code for up to 16 IP’s for free.
Thanks, I’ll check it out
For simple network testing putting a device on that network and running NMAP scanning for your other networks would be the easiest way. There are no currently known vulnerabilities that allow VLAN hopping in UniFi.
Cool, thanks for the suggestion Tom!
Most Pen Testers use Kali Linux, I’ve never used it myself but it must have everything needed.
I run Nessus and Greenbone CE.
I good tool for managing the results from several tools is DefectDojo.
