Synology to minio
Hi any quick guide out there to get hyperbackup working to a minio server
got mine quickly up and running on a windows 11 pro workstation
thanks
ps plan is to use the tailscale ip on the workstation in the hyperbackup config, then after the first “onsite sync”, move the workstation to a remote location with future syncs then being over the tailscale net
PPS WOW, followed Joels instructions here and installed deltacopy…
within 5 mins i was “rsync hyperbacking” to my windows workstation
elegant and simple… best solutions always are :slight_smile:
