Hi Tom,
I’ve been trying out Syncthing over the past few days (after having watched your videos) and I’m running into a persistent problem.
One one end I am using the Truenas Scale version and the other my windows laptop.
I chose a particular folder with some complexity Files: 341,729 Directories: 5,921 Size ~508 GiB to see if this could server as my daily driver and set it up to be a one way sync to my Truenas.
Enrollment / connecting to the two instances and folder seemed to work ok but after a few hours of transferring across my LAN (my Truenas is sadly still spinning rust) I found a state where the upload amount matched the file size, it seemed that directories were created, Truenas reported disk usage but the Local State on the Syncthing-Truenas showed Folders but 0 files.
I’ve now tried re-connecting, re-syncing and reinstalling all with the same problem.
I’m assuming there is a permissions issue on Truenas? App-user has full control so I’m not sure where.
Also of note, I’m running the latest TrueNas release and it didn’t give me that Host Environment disable option you talked about (not sure if that is still relevant?).
Thanks for the help!
