So I had a server fail to reboot after updates yesterday, reached out to Supermicro and got a very detailed response about how this wasn’t a supported system because it is so old, etc., etc. The guy spent more time saying what I can’t do with it than answering the beep code that I mentioned.
So does anyone know what 3 beeps, a pause, and 3 more beeps means?
They are low in frequency, not the higher pitch like a RAM problem, and I think they are longer beeps (longer than memory problem). It’s another code that is not in the book.
In the error log, the only entry from that time was an intrusion detection, which I should have defeated because the chassis doesn’t support it. Would chassis intrusion keep it from booting? I think the answer is yes but not sure. I’ll probably get to take another swing at this next month on exploit Wednesday when it needs another reboot. This is a production server running a second instance of my AD, plus WDS and is also my KMS host. I do have new servers on order, but it has been months and no word on when they will ship, and this is a bigger rebuild to put everything in an XCP-NG based system instead of individual hardware (a big project). Really want to keep this going until summer when I can move to VM or do a clean sheet rebuild.
