Hi everyone. First post.
Looking for some input on this personal project as I’ve never used or installed xcp-ng, nor TrueNAS (Scale) – this will be my first venture using both. I’ve been acquiring hardware for some time to build a new home server that will host a few general purpose linux VMs with one of those VMs being TrueNAS Scale for NAS duties. Plan is for a single xcp-ng host with local storage, no clusters. I’m currently stuck a bit on the local storage design / layout in terms of what would be optimal.
Server Hardware
- Supermicro SC846 4U case with the “A” backplane & “quiet” power supplies.
- ASUS Pro WS W680-ACE IPMI Motherboard
- Intel i7-13700k CPU
- 128GB DDR5 ECC RAM
- LSI 9300-8i HBA with (8) 8TB WD Red drives
- (3) 2TB WD SN850X NVME drives that will fill the MB’s (3) M.2 slots
- ConnectX-5 25GbE dual port NIC
I plan to pass through the LSI HBA and (8) disks to the TrueNAS Scale VM.
The debate is how I should setup the NVME drives. Should I:
- Setup the (3) NVMEs as local storage to the xcp-ng host, use them as the xcp-ng boot/OS drive and SR. Concern is I’d like to be able to use this storage pool as fast NAS storage for clients on the network, so if I did this, I’d want to share out some of this capacity to the network. 2TB is a lot for just xcp-ng boot and SRs. Also not sure what local storage options would work for 3 drives other than ZFS which seems to overly complicate the xcp-ng local storage. Could just use 2 and mirror if I go this way. Not sure how I’d share out a part of this local NVME space short of installing Samba or something on the xcp-ng host which sounds like a bad idea.
- Go buy a couple small/cheap SATA SSDs to act as the xcp-ng boot drive & SR. Connect them to the MB’s onboard SATA controller. Pass the NVME drives over to the TrueNAS Scale VM and setup the (3) NVME drives as a 2nd “fast” storage pool. Only downside other than cost and complexity is my VMs wouldn’t be hosted on NVME, only on the SATA SSDs – not sure that would be a noticable difference.
Favoring option #2.
Thoughts?
