Hello im having some trouble with multiple WANS on pfsense,
so my WAN gets 105.76.23.8 the local address that AT&T gives me and I also have a /29 block of static IPs from them im running pfatt and figured out how to pass my /29 through he NAT but I just cant find any documentation on having a differnt WAN IP for each physical interface on pfsense.
The config I want:
WAN 105.76.23.8 -> igb0
WAN 84.22.35.31 ->igb1 -> to a server
WAN 84.22.35.32 ->ix1 -> to another router
how would you be able to do something like this?
I’m unsure of how to get each interface to you a independent public IP.
I had a look at this and couldn’t get it to work, my use case was that we host remote servers for a business and they wanted each server to have a Public IP (we have a /29 -14 useable IP’s).
I have my IP’s configured as Virtual IP’s, but without losing two IP’s, I couldn’t figure out how to give a sever a public IP in the /29 range- I think due to the way my ISP hands out the IP’s (PPPOE).
The only option for the servers themselves to have an IP in the /29 is for them (the interface(s) they connect to) to be bridged with the WAN interface. Otherwise there’s no way to route the traffic.
The business won’t accept a 1:1 NAT to a private IP on the servers? It is a bit more of a pain, but it is the proper way to handle this type of ISP subnet assignment. The days of the ISP using a /30 and routing a /29 or larger to it are gone.
Still haven’t been able to accomplish what i’m trying to do, get a wan IP no problem on the default LAN interface (igb1) but cant get my static block from at&t to work on the other interface (ix2). Tried the documentation you gave me but its more for if your hosing, i just want every port available so i double NAT on the router plugged into it.
It almost sounds like you need to do policy based routing with multiple IP routing tables. I’ve only done this with a Edgerouter but you might want to research PBR or Policy Based Routing.
All i’m trying to do though is match public IPs to physical interfaces. Any good ideas of how to start off with policy routing, my big issue is that my knowledge of how to use pfsense is lacking, are you a Edgerouter user only?
Can you provide a little more information please. I’m assuming that you are NATing everything through Pfsense to internal (non-internet-routable) IP addresses. Is there only one internal LAN or are there two or more internal subnets? As far as sending traffic to an internal router, you will need to provide Pfsense with the static routes of internal IP subnets that might be behind the internal router. Pfsense does not know about what subnet or subnets are on the other side of that internal router. If you can provide more information that would be great.
Yes i am but for my router in my lab i’m trying to bypass a IP from my public block through the NAT, to a physical interface to just connects to my lab router.
This is how I would do this:
Create a bridge including ix2 and ix3
Assign 34.33.48.21/29 to the new bridge interface
(At this point your devices connected to ix2 and ix3 are online)
Create a virtual interface on the bridge for 34.33.48.25
Create custom NAT rules to achieve the desired NAT for igb 1
(These last two steps can be skipped if you’re OK for the LAN devices to be NAT’d to 103.22.30.x)
But so if my static block is 34.33.48.20/29 then i still Assign 34.33.48.21/29 to the new bridge interface right? and i still need 103.22.30.x to be my main WAN IP since thats how the box connects to AT&T, the 34.33.48.20/29 is just the block they give me over my 103.22.30.x link to them. Just making sure you knew that, that is why this wont work. That is why im having trouble configuring it. shown at this link
ok well then if i dont want to bridge the interfaces, what could you do instead, one ip is going to a router in my lab and the others are going to servers, want to firewall the servers but not the router, since it is a firewall. Do need to do policy based routing for something like that?
