Our company has a client that requires running 5 displays. Two weeks ago we purchased and installed this card in his system:
It has been working, but after upgrading him from 4GB to 8GB of RAM, I am only able to get two of the displays to work. I have tried re-installing the graphics driver, but no luck. This is frustrating because we have also tried using an RX550 in combination with an MST hub, but were never able to get more than 4 displays to work.
Does anyone have any advice? And what setup would you use to power 5 or more displays?
This is a way interesting issue. bonus that it sounds like an interesting rig
I have a couple of questions, is the card getting enough power & does the card work correctly by removing the new RAM? Not sure if this is the case, would be great if we could get some specs on the system to get a better understanding. Since it worked fine with the memory at 4 GB I wonder if the board just can’t pass the power over to the card. Just a thought, hope that helps.
From the vendor:
300W (or greater) power supply recommended
400W power supply (or greater) recommended for AMD CrossFire™ technology in dual mode
