Performance seems to be improved but I can not get apps to run because it tosses a Kubernetis error.
Failed to configure kubernetes cluster for Applications: Command ‘(‘mount’, ‘-t’, ‘zfs’, ‘MegaTank/ix-applications/k3s/kubelet’, ‘/var/lib/kubelet’)’ returned non-zero exit status 1.
Reading about this and googling it seems people had varying succes by deleting the IX-applications dataset, unsetting the pool and reassinging it…
No luck.
Error: [EINVAL] kubernetes_update.force: Apps have been partially initialized on ‘MegaTank’ pool but it is missing ‘MegaTank/ix-applications/k3s, MegaTank/ix-applications/k3s/kubelet, MegaTank/ix-applications/releases, MegaTank/ix-applications/default_volumes, MegaTank/ix-applications/catalogs’ datasets. Specify force to override this and let system re-initialize applications.
Lol… it says… “Specify force to override this and let system re-initialize applications.”
There is no force option as it is just an error message…
Anyone else come accros this problem and found a way to solve it?
